sharifi8 ارسال شده در 6 دی، ۱۴۰۰ اشتراک گذاری ارسال شده در 6 دی، ۱۴۰۰ معانی مخفف های نقشه خوانی موبایل ACI = Accessory Control Interface A/D-converter = Analog-to-digital converter ADC = Analog-to-digital Converter ADSP = Application DPS (expected to run high level tasks) AGC = Automatic gain control maintains volume ALS = Ambient light Sensor AMSL= After Market Service Leader ARM = Advanced RISC Machines (ARPU = Average revenue per user (per month or per year ASIC = Application Specific Integrated Circuit ASIP = Application Specific Interface Protector B2B = Board to board, connector between PWB and UI board BB = Baseband BC02 = Bluetooth module made by CSR (BIQUAD = Bi-quadratic ,type of filter function BSI = Battery Size Indicator BT = Bluetooth CBus = MCU controlled serial bus connected to UPP_WD2,UEME and Zocus CCP = Compact Camera Port (CDSP = Cellular DSP (expected to run at low levels CLDC = Connected limited device configuration (CMOS = Complimentary metal-oxide semiconductor circuit (low power consumption COF = Chip on Foil COG = Chip on Glass CPU = Central Processing Unit CSR = cambridge silicon radio CSTN = Color Super Twisted Nematic CTSI = Clock Timing Sleep and interrupt block of Tiku CW = Continuous wave D/A-converter = Digital-to-analouge converter DAC = Digital-to-analouge Converter DBI = Digital Battery Interface DBus = DSP controlled serial bus connected between UPP_WD2 and Helgo DCT-4 = Digital Core Technology DMA = Direct memory access DP = Data Package DPLL = Digital Phase Locked Loop DSP = Digital Signal Processor DtoS = Differential to Single ended EDGE = Enhanced data rates for global/GSM evaluation EGSM = Extended GSM EM = Energy management EMC = Electromagnetic compability EMI = Electromagnetic interference ESD = Electrostatic discharge FCI = Functional cover interface FPS = Flash Programming Tool FR = Full rate FSTN = Film compensated super twisted nematic GMSK = Gaussian Minimum Shift Keying GND = Ground, conductive mass GPIB = General-purpose interface bus GPRS = General Packet Radio Service GSM = Group Special Mobile/Global System for Mobile communication HF = Hands free HFCM = Handsfree Common HS = Handset (HSCSD = High speed circuit switched data (data transmission connection faster than GSM HW = Hardware I/O = Input/Output IBAT = Battery current IC = Integrated circuit ICHAR = Charger current IF = Interface IHF = Integrated hands free IMEI = International Mobile Equipment Identity IR = Infrared IrDA = Infrared Data Associasion ISA = Intelligent software architecture JPEG/JPG = Joint Photographic Experts Group LCD = Liquid Crystal Display LDO = Low Drop Out LED = Light-emitting diode LPRF = Low Power Radio Frequency (MCU = Micro Controller Unit (microprocessor MCU = Multiport control unit MIC, mic = Microphone MIDP = Mobile Information Device Profile MIN = Mobile identification number MIPS = Million instructions per second MMC = Multimedia card MMS = Multimedia messaging service NTC = Negative temperature coefficient, temperature sensitive resistor used as a temperature sensor OMA = Object management architechture OMAP = Operations, maintenance, and administartion part Opamp = Operational Amplifier PA = Power amplifier PDA = Pocket Data Application PDA = Personal digital assistant (PDRAM = Program/Data RAM (on chip in Tiku PIM = Personal Information Management PLL = Phase locked loop PM = (Phone) Permanent memory PUP = General Purpose IO (PIO), USARTS and Pulse Width Modulators PURX = Power-up reset PWB = Printed Wiring Board PWM = Pulse width modulation RC-filter = Resistance-Capacitance filter RF = Radio Frequency RF PopPort TM = Reduced function PopPortTM interface RFBUS = Serial control Bus For RF RSK = Right Soft Key RS-MMC = Reduced size Multi Media Card RSSI = Receiving signal strength indicator RST = Reset Switch (RTC = Real Time Clock (provides date and time RX = Radio Receiver SARAM = Single Access RAM SAW filter = Surface Acoustic Wave filter SDRAM = Synchronous Dynamic Random Access Memory SID = Security ID SIM = Subscriber Identity Module SMPS = Switched Mode Power Supply SNR = Signal-to-noice ratio SPR = Standard Product requirements SRAM = Static random access memory STI = Serial Trace Interface SW = Software SWIM = Subscriber/Wallet Identification Module TCXO = Temperature controlled Oscillator Tiku = Finnish for Chip, Successor of the UPP TX = Radio Transmitter UART = Universal asynchronous receiver/transmitter (UEME = Universal Energy Management chip (Enhanced version UEMEK = See UEME UI = User Interface UPP = Universal Phone Processor UPP_WD2 = Communicator version of DCT4 system ASIC USB = Universal Serial Bus VBAT = Battery voltage VCHAR = Charger voltage VCO = Voltage controlled oscillator VCTCXO = Voltage Controlled Temperature Compensated Crystal Oscillator VCXO = Voltage Controlled Crystal Oscillator Vp-p = Peak-to-peak voltage VSIM = SIM voltage WAP = Wireless application protocol WD = Watchdog XHTML = Extensible hypertext markup language (Zocus = Current sensor, (used to monitor the current flow to and from the battery 2 نقل قول لینک به دیدگاه به اشتراک گذاری در سایت های دیگر More sharing options...
